Can't decide between Hotchkis or DJM, 2/4
Hotchkins has figured out how to make these pigs handle pretty will. I would go with the McGaughy spindle and Hotchkins springs in rear. I would also add the Hotchkins sway bars!. If you are towning or hauling anything you are going to be banging your axle on the frame with a 4 inch rear drop. A set of Air Helper springs is the only remedy, besides a c-notch.
The spindles up front will give you the best over all ride quality and front end suspension and steering geometry.
Originally Posted by agreif
Why do you say that combo vs the other?
Andrew
Andrew
zblee
11-11-2015 12:41 AM
