Carrier Install Questions
#32
Originally Posted by KySilverado
Too late. Old races have been out for a long time. I dunno but I have always read never use a new bearing with an old race. I will be using stock shims except for the pinion shim. It got damaged.
Got the trans side pinion race in. New bearing and race for the rearward pinion is different than the stocker. So definitely gone to the dealer tomorrow.
James
#33
Got the damn bearing off the old pinion. It is a 37 shim under it. One of the new pinion bearings and race don't match what came off. Has the correct inner diameter and the race has the same OD the bearing is just deeper. Looks like the same O.L.
Note to self... take these to machine shops if there is a next time.
James
#34
Originally Posted by closet red neck
Here's the deal, mic the inner race seating area in the case where the stock race was, if the case is wide enough to accomodate the new race, then put it in there. Here is what I have found out from my little excursion. The manufacture machines the cases to whatever bearing and races they have sitting on the bench when they assemble these thing. That's why none of these so called "master rebuild kits" work. I bought the same thing as you did and only used the carrier bearing and races out of the kit. Everything else are paper weights. Are you sure the bearing is going the right way??? I thought that the pointed end goes to the top (which will face the trans) because the pinion shaft will slide in from the rear and then go forward.
James
James
The bearing on the pinion is the small one that sits directly behind the yoke and is facing the right direction. The one laying on the table is the larger one being pressed on and it will face the oppoisite direction as the one sitting on the pinion.
#35
Bearings are on, new races in and the pinion is in the rear and feels great. Don't trust my luck so I am mocking it up to see the mesh pattern before I put all the new stuff in. Used the old crush sleeve, without the new seal. Oiled down the new bearings, torqued down the pinion nut till the bearing pre-load felt like the old.
Should have the carrier in after supper. Keeping my fingers crossed.
sauldgold
07-23-2015 02:15 PM
FlowmasterMufflers
07-17-2015 03:26 PM
