Cart in front of the horse question????
I got ahead of myself and installed the HD2 shift kit today. I am sure it will take a week or so to get my re-tune to lower line pressure from a previous tune.
So do you think it will be OK to drive with the shift kit until then? Will my higher pressure settings hurt anything or just make it shift firmer?
I obviously will not be hammering on it until I get a re-tune.
I know you cannot answer for sure becasue we dont know what my line pressure is.
Thanks anyways.
FormerVendor
Have you tried to drive it to see how hard it really shifts? As stated it will shift firmer than it should. However at wot the transmission is only going to make the pressure it is capable of making. Even with tuning the max pressure can not be increased only reduced. If you are not going to get a tune for a while you could always put the factory boost valve and pressure regulator springs back in until you are closer to getting your tune done. If that makes sense. Vince
thewrx
08-12-2015 08:28 PM
