Changing Diff Fluid...question...
When i change the fluid out do i need to add that additive to the oil as well? The manual says if you have a limited slip diff to add it but how do i know if i have limited slip?
Originally Posted by FryZ71
What year/size truck? 1/2 tons with the 8.5" 10 bolt and RPO G80 Gov-Lok don't need the friction modifier additive.
My truck right now is popping and jerking because I didn't add enough additive.
If you have a locker.....you should use the Additive.
10 Second Club
Originally Posted by jdawg04 4.8
Brake stall to about 3000rpm and let the rubber burn if only one wheel spins and smokes you dont need the additive
Originally Posted by Torque_Wrench
I work at a dealership and I know to be fact, that if you got a Posi Trac (G80) you DO have to have the Limited Slip Additive.
