Changing Rear Suspension Plans
I wasn't really looking at an easy way out over hangers.
The problem seems to be with the Caltracs and hangers being used together.
One guy here said that the Caltracs bar actually hits his overload spring causing it to unload the suspension, which causes the tires to break loose.
The other issue is with the Caltracs not clearing the hangers, then causing the suspension to bind.
I really can't figure out why the Caltracs bar would hit the overload spring on the stock leafs. The guys using factory hangers and factory leafs don't have problems. The angle from the lower portion of the axle to the front eye of the leaf spring isn't changing with different hangers. So that would mean that all Caltrac owners would have this problem. IMO
I would have thought the Belltech leafs would have had great feed back, but it looks like they are getting bad feed back.
I don't know what to do...........
relocated shocks will get the thing to ride decent. Or for a temporary fix, run Viking adjustable shocks on the softest setting.
black03rcsb
09-01-2015 10:17 AM
