Chasing a high speed vibration
Old 01-02-2012, 05:12 PM
guero68's Avatar
Default Chasing a high speed vibration
I been chasing this high speed vibration for some time now. I believe something isnt right after the gear install but mybay its my pinion angle. The current pinion angles are (TRANS -4.4 pointing down... DRIVE SHAFT point down into the pinion or upto the trans depends and how you want to look at it 2.5 and PINION +4.3.....) I just had a new transmission built by ACE and now i can fell the vibrations more sine everything inside the trans is nice and tight. The drive shaft is a one piece from texas drive shafts 5in aluminum high speed balance 1350 spicer ujoints....
Do my angles looks off....this is driving me carzy i am thinking something is wrong with the pinion gear install....The vibration is a high speed vib that starts around 75mph and gets worse with speed....
File Type: pdf
Old 01-02-2012, 06:49 PM
Gadgetized's Avatar
Does it vibrate if you put it in neutral? When you are in the throttle it will force the pinion up a few degrees.
Old 01-02-2012, 09:18 PM
guero68's Avatar
Hmmmm....
Dont think its going to work since when i left off the throttle it continues to vibrate until i get under 75mph...but it worth a shot
Going to have to try that in the morning..will post finding after the neutral test...
Old 01-03-2012, 05:48 AM
guero68's Avatar
Well getting the truck to make the vibration and put it into neutral didnt help any... No change in intensity or anything....thinking it might be backlash issues
Old 01-03-2012, 06:13 AM
iamkeniff's Avatar
it could be a bad u-joint, did you check them before reinstalling the dshaft? Also check to make sure no weights are missing.
Are the u-joints in line?
Old 01-03-2012, 11:12 AM
guero68's Avatar
All the caps look good and doesn't appear to be missing any weights that were welded on..
What do you mean by line...like phased
Old 01-03-2012, 09:44 PM
11 Second Club
Phantom's Avatar
if it looks like the drawing you posted, that's your problem. The pinion and drive shaft should meet and form a V not a ^ or -
Old 01-03-2012, 09:45 PM
11 Second Club
Phantom's Avatar
Pinion Angle - Wolfe Race Craft
Old 01-03-2012, 09:46 PM
11 Second Club
Phantom's Avatar
you subtract the driveshaft angle from the pinion face angle. You have ~ 1.8+ pinion angle according to your drawing. That's where your vibration is coming from
Old 01-04-2012, 07:15 AM
guero68's Avatar
had seen that link..everyone talks about parralle lines and such...will give it a shot this weekend to see what going on....thank for the info..willl keep everone posted...
Quick Reply: Chasing a high speed vibration
