Check my gear setup- PLEASE
Originally Posted by Wilde Racing
I know alot of people use inpacts to install their pinion nut, but I wouldn't. if you crush to far there isn't no coming back, with that crush sleeve anyway.
Did you replace the pinion nut?
New pinion nut with locktite.
How do I change this text
Originally Posted by KySilverado
Yeah, I was apprehensive about using an impact but it was the only way I could get it done. I tried for 2 hours to work something with my limited tools, rear in truck on jackstands, to hold the pinion and put a breaker bar on it to crush the sleeve. I think ideally would be use an impact to pull it up till the bearings touch and finsih it with a breaker bar. I wound up with about 22" inch pound bearing pre-load using the impact but you could very very easily over do it if not taking it easy.
There is a trick I use to hole the pinion, Kinda a pain in the A$$, but, if you thorw the carrier assy back in, then throw the cross shaft in with-out the holding bolt, and rotate the carrier until the cross shaft silds part way out of the carrier and hits the rear-end housing and binds the whole assy up...
Closest I came was getting to some flats on the yoke. My largest adjustable wasn't quite large enough and it was to short to wedge against the ground.
Stainless Works
04-10-2016 04:34 PM
iregret
07-27-2015 10:32 PM
