The Chevy Lean
Old 10-21-2008 | 03:41 PM
jakebdb56's Avatar
Default The Chevy Lean
I used to have a thread bookmarked that had the parts to fix the chevy lean but I can't find it for the life of me. I just want to "correctly" fix the lean with the front end parts instead of adjusting the driver side shackle. thanks in advance
Old 10-21-2008 | 09:00 PM
14psisupra's Avatar
the front spring isolator?
http://www.stylintrucks.com/parts.aspx?category|category_root|-30=Suspension&category|cat_-30|373=Lowering+Parts&canned_results_trigger=&part familyid=3359
Old 10-22-2008 | 01:04 PM
chevythunder06's Avatar
In the 12's??????
I have the same lean problem with my truck and it drives me nuts. This Spring Isolator Bushing will cure the 3/4" difference from side to side in the front, but will that in turn cure the rear, or will that be a totally different issue to be addressed?
Old 10-22-2008 | 01:27 PM
black06's Avatar
there is a small set of spacers will install to cure the problem. one coilspacer up front and a 1/2 spacer for the rear
Old 10-22-2008 | 04:04 PM
jakebdb56's Avatar
Originally Posted by 14psisupra
gracias senor, I'm gonna make sure the same part will fit my truck.
Old 10-22-2008 | 04:17 PM
jakebdb56's Avatar
I got the dimensions from Belltech, going to make my own once I drop my truck next weekend.
madmann26
04-29-2020 10:17 AM
Pimpinpete
43
12-22-2017 09:13 AM
03sierraslt
14
10-09-2015 06:53 AM
BlownHD
10-03-2015 01:24 PM
02AWDAWSDenali
10-01-2015 06:08 PM
