Circle D - 278mm 3200
#41
When the stall is listed in a range like you mentioned above (emphasis added), do things like the engine size/cam/gear ratio affect where in the range it kicks in?
#42
Is this the same as the 2600-2800/3000-3200 278mm? Or just for the 3000-3200? I'd like the tighter version. Unless you're just giving a ~ range from 2600-3200 depending on vehicle, etc...
#44
felt like this thread needed a bit of a jump start, haha
#45
Sorry guys, I let a few questions go unanswered.
I rate our converters in a range because there are so many factors involved other than the converter. So I set a small window where I expect it to flash. There are numerous factors that will affect the stall. Engine power and power curve, so a cam will make a difference. Vehicle weight and gear ratios also come into play.
Also a reminder, we are still running the special on the 278mm converters. $375 with shipping. Just mention PT when you call or use coupon code "278mm" when you order online. Thanks again for all the sales, you guys are keeping us very busy.
Chris
Chris
