Circle D vs. Yank
Old 01-12-2011, 02:15 PM
skoal bandit's Avatar
Default Circle D vs. Yank
I know both are good converters. But has anyone did any testing to see which one had more slippage than the other one, causing less power to the wheels? And i'm more talking about their bottom of the line ones not the $$$ ones.
Old 01-12-2011, 02:21 PM
Wearin' da big hat
00ChevyScott's Avatar
Buy both and let us know
Old 01-12-2011, 02:22 PM
sure! send me some money!
Old 01-12-2011, 02:43 PM
13 Second Truck Club
grey matter 04's Avatar
From both yank and circle D's web page!
Yank has a better description and spec sheet ...
YANK TRUCK THRUSTER 3000 4L60E/4L65E
278 mm, 3000 stall, 2.21 STR, 98.6% efficiency! This converter is a modified Truck Thruster 2600. Being so, it shares the stock-like appearance, super-high efficiency, and impressive towing capacity of its lower stall brother.
Circle D needs more detail...
Torque Converter Diameter: 278mm - 11"
Stall speeds 2600 to 3200 RPM
Hand TIG Welded
High Carbon Spun Wound Lock-Up Clutch Lining
Heavy Duty Torrington Bearings
Old 01-12-2011, 03:07 PM
I'm wondering if that 98.6% efficiency has alot to do with my times being slow...being I have a Circle D. I wonder if Circle Ds efficiency is lower.
Old 01-12-2011, 03:27 PM
charcoal03silvy's Avatar
I've heard Yank's are tighter. But then also heard the same about Circle D
Old 01-12-2011, 03:38 PM
i own a yank and have drove a circle d
yank is tighter which i preffer a tight stall
Old 01-12-2011, 04:09 PM
Bumpers's Avatar
They both feel bout the same to me
The more torque you have the looser it will feel
Old 01-12-2011, 04:14 PM
Talked to Circle D and they should be VERY close to the same. Circle D is 2.2 STR and Chris said efficiency should be very close too. Its basically the same 278mm converter before they start with it.
Old 01-12-2011, 04:15 PM
kinda off topic..... I can't find the the rework TB converter on Circle-D's site
Quick Reply: Circle D vs. Yank
