clamped leaf springs
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
ill try them on the rear for track use only, i dont want it riding rough. im not into having a DD bagged truck/1" suspension travel truck anymore
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
I put the spring clamps in the front, just to stop wheel hop at the track. Sprays truck does hook well with his setup. I cut 1.74's without the clamps & have Only cut 1.75's with them
Mod with training wheels
So logic tells me that clamping the springs on either the front or the rear would change the pinion angle... What are you guys doing about that? Clamping the front would certainly add to the pinion angle, likely enough to the point where drivetrain torque will cause a vibration.
