Clicking front end
![Post](https://www.performancetrucks.net/forums/images/icons/icon1.gif)
It's going to be one of these items:
-inner tie rods
-outer tie rods
-upper ball joint
-lower ball joint
-wheel bearing hub assembly
-intermediate steering shaft (very common)
Depending on miliage you could have a combination of front end parts worn.
Take it to a good mechanic shop that does wheel alignments daily. They will be able to tell you what the problem is. This may be a good time to know what your alignment looks like on your truck (many neglect this maintenance item which is recommended to be checked every 15,000mi).
If you have any NTB's, Tire Kingdoms, Tire Merchants, or Big O Tires where you live, they will check out everything for free.
Hope this helps.
Jim
-inner tie rods
-outer tie rods
-upper ball joint
-lower ball joint
Hope this helps.
Jim
Corvette454l88
09-01-2016 01:24 AM
5.3Caprice
11-07-2015 08:56 PM
Offroadunleashed
07-20-2015 02:25 PM
