Clicking noise from front of trans???
10 Second Club
I just bought a 2000 Silverado 1500 w/ the 5.3liter and when I start it and let it run, I can hear a clicking, almost like a exhaust leak, crawl underneith and the 2 plastic guards near the oil pan and trans are slapping against the bellhousing? Feels like somethings hitting if you put your hand on the plastic? You rev it up and it ticks faster as you rev up higher? Sometimes it goes away and sometimes dont.. And when I go from park to drive or reverse its not even noticable anymore..And ideas?
10 Second Club
Is there anything I can do to quiet the noise? If i get underneith the truck while its running and push in on the plastic cover its feels like its slapping pretty good.. Someone recommended Lucas Oil Stabilizer?
Check the Torque on your Converter bolts.
My guess is that they are loose. My 86 Chevy did that.. kind of a tick tick tick.... put it in gear (Load the trans up) and it stops.
Flywheel to Torque Converter Bolt: 63 N·m (46 lb ft)
10 Second Club
Took out the starter and glanced at the converter bolts and sure enough 1 was almost all the way out, one was about 3 turns loose and one was tight.. Tightened them up and no more click.. thanks for the help
Hey You Got Off Lucky.... When My Wagon With An 88 Vette Motor Did That.... I Had Actually Twisted The Bolt Pattern Out Of The Middle Of The Flywheel
Originally Posted by vanillagorilla
I did that once on my Camaro! High stall torque converter, slicks and a stock flexplate don't mix.
yeah a tci cured my problem though
black03rcsb
09-01-2015 10:17 AM
