Close Ratio Gearing for a 4L60E
Old 12-18-2007, 12:15 AM
LS1TECH & Trucks Sponsor
performabuilt's Avatar
Originally Posted by Dirty Dave
Well crap I think you're right. The 4l60 carrier has an extra set of splines.
Yep but good idea
Old 12-18-2007, 11:51 AM
Savage Sierra's Avatar
Lightbulb
Originally Posted by built
just get a higher stall converter. will have less rpm drop on gear changes.
A higher stall converter will limit the shift drop but it does nothing for actual acceleration. I know back in the 70's and 80's a lot of the drag racers were running Power Glide Transmissions because they only had two gears and they had a close ratio. I had one in my 10 second Nova. If any of you guys have ever driven a close ratio tranny compared to a standard street geared automatic you would know what I mean. Its like going from a 3.08 to a 4.10 rear gear but that thrust and pull is there in each gear.
I was just wandering if it could be or had been done with an electronic transmission. It was just a thought. I think a heavy truck would benefit from closer ratios. IMO.
Old 12-18-2007, 05:24 PM
YenkoST's Avatar
You can put a gear vender overdrive unit on it...have 8 gear automatic.
Old 12-18-2007, 05:43 PM
I wish I didn't have an overdrive now. I like my final gear to be one to one. But I guess it helps mileage, like I care about that!
Old 12-18-2007, 06:42 PM
YenkoST's Avatar
Its not just mileage but the lower rpms help the longitivity of the engine.
Old 12-18-2007, 10:50 PM
Thumbs up
Originally Posted by YenkoST
Its not just mileage but the lower rpms help the longevity of the engine.
I'm not disagreeing with that, but I would think that all that lugging around at low rpm and constant downshifting would be harder on the drive train...?
Old 12-18-2007, 11:22 PM
YenkoST's Avatar
Lugging at low end is actually rough on the engine b/c the timing, etc. However, if you don't have any knock, then you should be fine and should be a problem. The constant downshift...not really unless you constant WOT it and break traction and catchs.
Bluecollar Hotrods
06-11-2024 11:37 PM
chopperloco
07-10-2016 10:45 PM
Noah Burns
10-05-2015 06:46 AM
Jake99
08-08-2015 07:56 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Close Ratio Gearing for a 4L60E
