coil spring to torsion bar front end?
Old 12-07-2010, 07:18 PM
dlt76028's Avatar
Default coil spring to torsion bar front end?
Just wondering what all would be needed to convert a 2wd coil spring to 2wd torsion bar front? From what I can see, UCA, torsion bar, crossmember, what else???
Old 12-07-2010, 07:50 PM
bighoss77's Avatar
im pretty sure the mounts on the frame are different.
Old 12-07-2010, 07:53 PM
13 Second Truck Club
DV2000NJ's Avatar
Obviously the LCA too.
I could be wrong, but I thought that the mounting points on the frame for the control arms were different.
Old 12-07-2010, 08:00 PM
dlt76028's Avatar
the torsion bar goes into the uca right? I just figured the lcs wouldn't need to be changed. If the arms mount to the frame differently then never mind...
Old 12-07-2010, 08:30 PM
DV2000NJ's Avatar
Torsion bar goes into the LCA. I believe the UCAs are different too. The 2wd frames also have the coil buckets too.
I've never been under the front end of a 2wd truck, so I won't be a whole lot of help.
thunder550
10-08-2015 04:53 PM
Kaldar
07-27-2015 06:42 PM
signguy62
07-25-2015 03:12 PM
Offroadunleashed
07-20-2015 02:25 PM
Quick Reply: coil spring to torsion bar front end?
