Completely stock 06 GMC Shift then Clunk
Old 10-25-2011 | 02:14 PM
ig109's Avatar
Default Completely stock 06 GMC Shift then Clunk
Ok,
Truck is completely stock with 198K miles on it.. L33 engine, 4x4, stock tires, stock gears, stock tune, stock trans. 85% highway miles... I picked it up cheap due to miles and since then this issue has shown up..
It is really a mere annoyance at this point but i will see if anyone else has had an issue like this..
It occurs on part throttle shifts at traffic lights.. the 1-2 shift occurs, then there is a thump.. not a noise a feeling.. like someone hit the frame with a rubber mallet.. Not harsh but not soft either.. There is about a half second delay from shift to thump.. I have been under truck, mounts appear to be ok (from what i could see late in the evening) and after that it doesnt do it again until you stop and it goes from 1-2 again..
Any ideas???
Old 10-25-2011 | 02:23 PM
Atomic's Avatar
I have a gauge for that
ujoints?
Old 10-25-2011 | 02:25 PM
ig109's Avatar
Have yet to pull the shaft but just looking at them/ checking for excessive play they seem fine..
Will pull shaft tonight and report findings..
Old 10-25-2011 | 02:52 PM
dlt76028's Avatar
It's the famous Gm clunk. Take your driveshaft out and grease the crap out of the tail housing. That will last awhile. I plan on cutting a bounce ball in half and putting in there so its not hitting metal.
Old 10-26-2011 | 08:29 AM
ig109's Avatar
Is that the same as the ford no grease clunk.. Just the slip splines on the Driveshaft binding...
Is it actually bottoming out or is it just binding and unbinding on the slip??
Thanks
Ketis
07-23-2015 01:37 PM
lxcoupe
07-14-2015 11:14 PM
4B11T
07-13-2015 04:48 PM
ferrellrooster
07-13-2015 10:53 AM
zaathur151
07-06-2015 11:57 PM
Quick Reply: Completely stock 06 GMC Shift then Clunk
