converter shudder fix, look here
i had a converter shudder with my 07 yukon, 70k miles on it. it was slight and then started to get worse when towing over the past month, called GM dealer and they said it needs a new converter but with the turbo the waranty wont cover it. $1400.00 to have them do it.
here is what i did
flushed the transmission with mobil 1 synthetic tranmission fluid, added a bottle of positrac friction modifyer,
i drove the suv 1000 miles so far and no shudder, previously it was bad enough to hear the vibration.
hope this helps you guys
here is what i did
it does not mean the converter is toast, i spoke with a few 4l60e converter guys and they said the clutches get dirt on them, like a film and a full flush and some additive will fix it, i actually tried this on my brothers tahoe, 07 also, his shudder is gone and that was in february of this year, he has about 15k miles on his since doing it, but his suv is 100% stock also.
4l60e has a pwm clutch. pulse width modulated. therefore its very rare you have a full apply inside. when he feels the shudder is during the slipping of partial apply. a "glaze" can build up on the clutch causing a shudder from an inconsistent apply. thats why the modifier can cause it to go away and can actually keep it away. it most likely wont cause any other damage to the trans. there is some stuff called shudder fix i have used for years on problem transmissions for cheap car lots.
Custm2500's Rude Friend
