Converter temp getting high
13 Second Truck Club
i just got my truck back with the 4L80e and a 3000 stall put in it. I did the stall twice in a row, how hot should it be? I called the place that installed it and they said that the converter heats up alot. It reached ~235 and then i parked it and let it cool down. Still runs fine but i got worried.
....boy does it shift hard! < thats my 3 gear scratch! haha
Got a tranny cooler on it? Or look into a deep aluminum tranny pan, both will help with the heating issues, Im not too sure on how hot is too hot, but with transmissions better safe than sorry.
My temps depending on how hot it is outside.right now day time is 80-100 deg.
freeway speeds 140-165 depending if i'm on it or not
city 140-175 stop and go
track 150-190 depending if i'm hot lapping normaly 170 after a burn out and pass.i turn of e-fans before my pass
never seen it go above 190 no matter what i do
4l80e and hughes 3000 10.5" that is loose and flashes at 3800
i'm runnin a b&m trans cooler#70266 and a mag-hytec deep trans cover
235 is not good i freek out when i see 190 at the track
heres some info on temp to trans life from mag-hytec
175 deg. 100,000 miles
195 50,000
215 25,000
235 12,500
255 6,250
275 3,000
295 1,500
315 750
hope some of this feedback and info is usefull to you.
195 50,000
215 25,000
235 12,500
255 6,250
275 3,000
295 1,500
315 750
LCHEE
10-24-2020 04:10 PM
TX Tahoe Z71
09-01-2015 09:11 PM
ullose272
07-19-2015 04:14 PM
ullose272
11
07-17-2015 07:22 AM
