Converter won't bolt up!
#21
Originally Posted by hellbents10
I have yet to have problem bolting a PI up in any silverado SS's or S-10's for that matter.
I start all of the bolts loosely then tighten. Do not put in one at a time and tighten as the PI's are usually really close to the insides of the three holes. You will have fun trying to bolt it up then.
I ground each hole individually and then put the bolt in. I then put the first bolt in loose then move to the next. It would still not go in. I had to go all 3 holes again about twice until I could get them all to start. Then went back through all of them and tightened them down.
#22
Adkoonerstrator
There are three different GM bolt patterns. I got some info from TCI's website.
The PI 4L80E converter I have has a 10.75" bolt circle. That is a small GM pattern. Just measure from the center of the converter to the center of a bolt hole on one of the mounting lugs. Then double that measurement to see which pattern you have.
http://www.tciauto.com/tech_info/converter_dims.htm
GM Small 27.31 (10.750)
GM Large 29.21 (11.500)
GM LS1 (300mm) 27.94 (11.000)
If you end up needing a "flat" flexplate you can get a 14.13" 168 tooth internally balanced flexplate with whatever old style pattern you need. Most regular flexplates come with a dual bolt pattern(GM large and small). I'm not sure if any come with the LS1 pattern except for stock GM ones. My PI converter had the GM small pattern and I need a flat flexplate so I ordered a 14.13" 168 tooth internally balanced dual pattern SBC flexplate. The nice thing about the SBC flexplate is it's CHEAP!!!
I still don't know for sure which swaps exactly will require a "flat" flexplate though.
#24
This is the kind of stuff (along with improper stall speeds, etc.) that made me decide to keep the stock converter in my truck.
A problem like this should be easily avoided - this should be a question they already have an answer to when you tell them what vehicle you have.
Did you ever hear back from PI?
#25
single digit dreamer
#27
All above aside. Stall is pretty darn close. Brake stalls to at least 2500. I'd say flashes to 3000-3100. I recommend you consider a moderate stall. It is eye opening.
#28
Originally Posted by parish8
in my opinion you are missing out on one of the best mods out there.
I drive like an old man 95% of the time, so my biggest concerns is everyday driveability. This is what had me initially leaning toward the Yank TT2600, but after all of their quality and customer service issues, I decided to stay away. So I'm interested in hearing about how this works out for KY.
#30
I've been seeing an increasing number of people having clearance problems between the converters and flexplates. I am starting to wonder if there are not a bunch of converters out on the market with old SBC bolt patterns that are getting 33-spline turbines installed and then getting labeled a "Gen-III / LSx Converter."
Having to grind the holes in the flexplate for placement is ABSURD. I can see enlargening the diameters of the holes to acommodate larger race-ready converter bolts, but having the wrong pattern is CERTAINLY something I would return a converter for, especially after spending what these things cost. Besides the cost of the converter itself there is too much money in front of and behind a torque converter to put something fudged in place like that.
