Converter won't bolt up!
#31
10 Second Truck Club
Originally Posted by KySilverado
Now I'm worried I might not even have right converter. Can anyone verify this part number as 10.5 Vigilante 3 disk for a 4l60E. Part number 2700318-3.
#32
Originally Posted by James B.
I've been seeing an increasing number of people having clearance problems between the converters and flexplates. I am starting to wonder if there are not a bunch of converters out on the market with old SBC bolt patterns that are getting 33-spline turbines installed and then getting labeled a "Gen-III / LSx Converter."
Having to grind the holes in the flexplate for placement is ABSURD. I can see enlargening the diameters of the holes to acommodate larger race-ready converter bolts, but having the wrong pattern is CERTAINLY something I would return a converter for, especially after spending what these things cost. Besides the cost of the converter itself there is too much money in front of and behind a torque converter to put something fudged in place like that.
I agree. I plan to get a Daaco for my truck. But its a 4x4. If I drop the trans and transfer case and it doesn't fit I'm gona be Pissed
#34
As an update guys. Just got hold of PI today. They were on vacation shutdown last week. So far they are telling me that ALL LS1 style converters they sell/make are done so on a 10.75 bolt pattern. They've sold lots of these and I am the first to call back and tell them it will not fit. Buried in this thread is that the LS1 style flexplates are on a 11.00 bolt pattern as is mine. Things that make you go hmmmmmmm.....
#35
what a rush!
thats wierd.
#36
Adkoonerstrator
Well, I've tried to find a flexplate that actually will work on a 10.75" bolt pattern with the crank spacer that doesn't have to have the holes ground out and there just ain't one. I got the TCI dual pattern unit today to test and it is flat but, is built to space everything the same way a stock "bent" plate does.
If the PI was built with a 11" LS1 pattern I think the stock 6.0L plate would work without reaming the bolt holes out.
#37
As an update guys..... So far they are telling me that ALL LS1 style converters they sell/make are done so on a 10.75 bolt pattern. They've sold lots of these and I am the first to call back and tell them it will not fit.....
#38
I also called TCI today and asked about their LS1 flexplate. They confirmed it was dual patterened. LS1 and 10.750. I will probably order one of these in preperation for the next time I am into the verter areas to replace my hacked flexplate. Either when I replace the vig or when I put in a built tranny.
#39
Originally Posted by moregrip
wow!
thats wierd.
thats wierd.
#40
Well of course, the "solution" to the "problem" is to DENY the problem exists.
