Corvette Servo
Ok thanks. Maybe I'll flip mine around. My 1-2 part throttle shift is getting a little sloppy with age and miles. It also sometimes sticks in second instead of downshifting all the way to first when coming to a stop.
Check your 1-2 accumulator piston. If its plastic its possible that its cracked and this could be your problem. What happens is you have main line pressure on one side of the piston in first gear. On the other side of this piston is where 2nd gear acc. oil will be in 2nd gear. In first gear if oil pressure is on the 2nd gear side it will apply the band. Not saying this is your issue but it is certainly something I would check. If you have a plastic piston upgrade to an aluminum one or a pinless sonnax piston. HTH Vince
8 Second Truck Club
hey yall servo came in today im gonna swap it in the a.m. is there any more info on the flipping of the 4th gear piston i read in the above sticky it says put it on the same way it came of does this apply when flipping it
