Crank spacer with SFI flex plate
Just installed the new Circle D converter and SFI flex plate. Distance from the flex plate to converter lugs is right around 0.230". Seems a bit excessive...has anybody needed to use crank spacers with SFI flex plates?
Well, I was able to space the converter off of the flex plate with some .070 washers, bringing the clearance down to within tolerance. But, I get an odd click sound at startup now. Seems to go away after about 10 seconds of running. Tried to get a video of it, but the audio is horrible. Its supposed to be a Hughes SFI flex plate. Not entirely sure what the sound is coming from... Pulled starter, converter bolts look fine, had a mirror behind the flex plate and rotated it, no signs of scraping or any other damage.
I noticed in other pics with engines that have SFI plates, the SFI cert sticker is facing the trans. The stock plate and the SFI one looked identical save for a small height difference---installing it the same way the stock one was installed put the SFI sticker on the engine side. Is this sticker always supposed to be on the trans side?
There were no markings. Flipping it to the other side would move the converter-plate clearance from 0.230 to like a full inch. Not to mention it would probably smash up against the block So it has to be on the right way.
But the sound does go away after like 5-10 seconds, sometimes sooner. Maybe the starter isn't disengaging the plate soon enough. Over on LS1tech a few guys have used shims to fix various starter issues. Wondering if that might be my solution..
