cryo-tempering
PT's Slowest Truck
Originally Posted by Bish
It definitely works. I studied metalurgy in college and cryo is used in many applications. Became poular with competition firearms and now is used in lots of places. I have cryo treated rotors and pads. I don't think you need to treat the whole transmission but I guess it would work, I jsut don't see the benefit. I know Chuck @ FLT is a fan of cryo treating certain parts.
Originally Posted by milan
Excuse my stupidity but how does a 4L80E affect California Smog laws?
AintNoHo thank you for clearing that up. I just didn't think changing over to another factory trans violated the smog laws since it is offered in other trucks. I figured it was carb certified but since you have the 93 Blazer I can see how it might not pass.
Trey- Cryo does claim more wear resistance- (gears last longer and turn with less friction), in addition it claims greater ductility (bleeds off heat like aluminum to prevent heat failure) and greater tensile strength (takes more pressure before it fails like a high tensile bolt). At temperatures near absolute zero the carbon flows to the flaws in the metal surface and on reheating crystalizes into a hard bond. That's why best results are with high carbon metal and plastic. Cheap steel doesn't get good results. Cryo also works to a lesser extent with aluminum but I don't understand why. Those are the claims, I'll see for myself if it works better than the fuel line magnet and octane rearranger. Maybe they'll claim I have cheap steel.
my old boss, when i did some motorsports stuff, told me cryo was useless in a trans because it did little in increase strength. safe to say he knew his stuff. Dont exactly get to be a VP of engineering with bullshitting.
made sense, because wear and tensile strength arent always hand and hand.
Originally Posted by hrodgmc
Why does FLP and other companies do it? They could save $200-300 and the extra hassle. I prefer cryo'd over hardened.
I dont know why they do it, but just because they do it doesn't mean its done to make them stronger. might even be a "make you feel warm and fuzzy" or increase wear resistance thing
Who was your boss?
