d@mn P.O.S. G80
Old 03-23-2009 | 08:57 PM
dirt track racer 81's Avatar
Originally Posted by GMCtrk
Don't take this advice and come back complaining because the gears whine down the road. I think someone on here just had this problem and ended up having the mechanic go back in and check the gears because he thought the gears were set up wrong; turns out it was just the inherent nature of the gears.
OEM AAM gears cost a whooping $50 more than Motive gears ($150 vs $200) and only $10 more than Yukon gears and are superior. Ron will take care of you, he has for many members here
im not talkin about the oem aam gears. im talkin about the value gears that come from rons as well.. i believe any how.. https://www.performancetrucks.net/fo...d.php?t=435933 read thru this thread on the value gears
Old 03-23-2009 | 09:01 PM
GMCtrk's Avatar
well, ya know, the saying you get what you pay for.
Ive read that the AAM's are heat treated to 1500 degrees from the factory....so they'd be pretty much broken in from the factory and release less contaminants into the gear oil on break in (mine was pristine @ 500 miles)
Although, I do recall dirt track racer saying he was going sideways coming out of the gear shop
Old 03-23-2009 | 09:06 PM
I was coming sideways out of a gear shop?? I do my own set up. I dont have any shop do any work on my truck.. i have done 30 or so gear swaps at where i used to work. and a few of those members are on here. the only ones ive had whine are richmonds and joshes value gears.. which several people have mentioned that they whine. first time with those gears. never heard any motives whine or ford motorsports gears whine either
Old 03-23-2009 | 09:17 PM
GMCtrk's Avatar
My bad. some reason thought I read that in a thread regarding gear break in...
anyways, my opinion is to go with the oem gears and ill leave it as that.
Old 03-23-2009 | 09:25 PM
Phantom's Avatar
11 Second Club
Motives are definitely the best aftermarket gears around. No noise.
Old 03-23-2009 | 09:26 PM
oem gears are best thats what they put in from the factory for a reason..ive just always got a good deal (a shops cost) for motives thats why ive always used them had good luck..
Old 03-23-2009 | 09:27 PM
dlt76028's Avatar
Also, here's a nice read on the Eaton LSD vs. the Eaton Detroit Trutrac (Eaton also makes the G80 BTW)
https://www.performancetrucks.net/fo...LSD+vs+trutrac
i thought auburn made the g80?
Old 04-06-2009 | 06:50 PM
Slimsilverado's Avatar
TRU TRAC baby FTW
Old 04-13-2009 | 10:28 AM
hog's Avatar
hog
Eaton originally made the G80 or Gov-Lock locking rear differential.
Eaton also makes:
Detroit Locker
TruTrack
Carbon Fiber clutch style LSD 200lb/400lb/800 preload plates are available-400lb preload comes stock
Eaton bought out Tractech a while ago. Tractech originally made the Detroit Locker and detroit Truetrack.
peace
Hog
Old 04-13-2009 | 03:30 PM
bgray's Avatar
TOTM: June 2007
I went Tru trac based on the fact there is no clutches towear out. It works seamlessm and locks with minimal torque applied.
I have yukons and they whine like a stuck pig.... but i also have headers and corsa's...so i cant hear them lol
Quick Reply: d@mn P.O.S. G80
