Deep ANUS?
Deep ANUS?
I saw a post the other day about deep pans. My first thought about deep pans has always been "Why waist money?" My understanding is deep pans are for added fluid that has one benefit, extra cooling. If that is the case why would you every waist a penny on a pan when you can add a large cooler that will do a much better job. If you want to add another quart or so of capacity why not add an external filter so you have a bit extra capacity and extra filtration.
Is there any other reason for extra fluid outside of the cooling?
Stock taper back 80e pan sucks for hard launches as fluid sloshes out of pan. Maybe someone is running the largest cooler they can fit and want more capacity and cooling. Cooler doesn't do a whole sitting still, so someone on a trans brake needs the capacity for cooling. Numerous reasons.
Formerly ScreamingL
Therfore it seems like waisted money in my eyes. That is why I asked. If you can get a pan around $100 it makes much more sense. The added strength is also a good point.
