Deep ANUS?
Old 01-26-2015, 09:25 PM
  #31
Jordan927's Avatar
OK....seeing as how GM used shallow and deep pans on the 4L60E (p/n 24229658 deep...used on trucks and P/N 8667545 used on everything else, S-10 came with both styles) Also they increased the depth of the 4L80E pan in 97 to 2.9" from 2.6"..I'd say a deeper pan is a good idea.
Old 01-26-2015, 10:30 PM
  #32
Suburbazine's Avatar
Originally Posted by James B.
Wtf. Unsubscibing
Did I ruin it for you?
Old 01-27-2015, 07:23 PM
  #33
JFOLM's Avatar
Originally Posted by custm2500
So then the intelligent response would have been:
Some times in race applications the added fluid and the finned aluminum pan provides enough cooling to not run a trans cooler at all.
Do you have any pictures of a set up like this? A majority of race cars I have ever seen have a cooler with a fan.
So all of your useless trash talking posts only showes you aren't here to help but be a jerk because you foolishly think I am an idiot.
Fans are a method of cooling.
Pans are a method of cooling.
Fins means more surface area for cooling and they also extract heat away from the fluid.
Old 01-27-2015, 09:01 PM
  #34
shupe's Avatar
This is funny.
Old 01-27-2015, 09:23 PM
  #35
Resident Retard
BlackGMC's Avatar
Speaking of deep pans. Do you have to run an extension to the filter or do you buy a different filter?
Old 01-27-2015, 10:00 PM
  #36
Choda's Avatar
The ones I've read use an extension that comes w the pan
Old 01-28-2015, 05:16 PM
  #37
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
i just installed a HUGHES deep pan on my 80E and to be honest i don't think it helped much i have a 30K trans cooler also
mine didn't need the filter extension used a stock type filter and it came with all the hardware i needed to install it
Old 01-29-2015, 10:04 PM
  #38
shupe's Avatar
The deep tci pan on my 80 required the extension.
Old 01-30-2015, 02:52 PM
  #39
High on diesel fumes
thunder550's Avatar
I am not a trans expert by any means, but FWIW I was told by THE Allison guru not to waste my money on a deep pan when I had my trans built.
Old 01-31-2015, 09:31 AM
  #40
Ph.D. in HUBRIS
custm2500's Avatar
Glad to see some intelligence showing up in this thread! It is nice when people reply with some decency and answer the question. Much more useful to all of us then the jerks who see my name on the thread and instantly walk in and poop in the reply box.
A pan will do very little for cooling the fluid, especially at a stand still. Added capacity will add a bit of resistance to heating up simply because you have more fluid to heat up to any given temperature. The capacity also gives a tiny bit more time before it is re-heated by going through the trans but we are talking 16% more fluid if you add 2 quarts and 25" if you are adding 3 quarts so it isn't much.
Your opinion may differ but from the facts that I can find they are as useful as a tornado. If the cost of the pan makes you feel more comfortable, that is it's value.
Quick Reply: Deep ANUS?
