Denali w/ whipple tow truck what transmission?
Old 09-03-2008 | 10:18 PM
Bromaguire's Avatar
Default Denali w/ whipple tow truck what transmission?
What transmission setup would work best for me? I have a 2003 Denali with a Whipple running at 12psi. I use the truck to tow about a 5000lbs boat. So far I have blown up three 4L65E built transmissions, whats my next step do I need to swap to a 4L80? I want a built proof setup so I dont have to worry about it all. I also like to drive the truck fast when not towing so I need something that can take the abuse. Any recommendations?
Old 09-03-2008 | 10:23 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
A FLT 4L80e Lv 5 and don't look back.
Old 09-03-2008 | 10:26 PM
tarinitup's Avatar
9 Second Truck Club
^^ I'm with stupid. Or you could do a level 4 4l80e from them. It has held up to lots of abuse over the past year or so
Old 09-03-2008 | 10:46 PM
Bromaguire's Avatar
What all is need to convert from my 4L65 to the 4L80? Is there anywhere that sell a conversion kit?
Old 09-03-2008 | 11:14 PM
nonnieselman's Avatar
Ive never seen what the under side of a Denali looks like but the 80E swap i did in my truck was a peice of cake.
Denalis are AWD right?
Old 09-03-2008 | 11:17 PM
Bromaguire's Avatar
Yeah they're AWD.
Old 09-03-2008 | 11:20 PM
I guess it depends on the Transfer case then?
Theres a gear swap or output/input shaft swap you have to do.
But other than that, everything else is easy.
You will have to fab up a Crossmember which only needs to be moved 6" to the rear.
https://www.performancetrucks.net/fo...d.php?t=413157
Old 09-04-2008 | 12:33 PM
kbracing96's Avatar
Don't forget about the drive shafts. In the 4wd 4l80 apps, they are 2 inches longer then the 60's so the rear shaft need to be shortened, and the front shaft need to be remade 2 inches longer.
Old 09-04-2008 | 01:20 PM
Bromaguire's Avatar
Is there any shops that sell the conversion kits or do I need to gatther all the parts myself?
wrb002
08-31-2015 01:00 PM
black6spdz
07-16-2015 02:32 AM
03sierraslt
07-11-2015 03:47 PM
Nimoryan
07-05-2015 04:50 PM
D1SCSS
07-03-2015 07:08 PM
Quick Reply: Denali w/ whipple tow truck what transmission?
