Detroit true-trac who's had issues
I had that same exact issue, the side gear on the driver side ground the case down and the only indication I had of an issue is when the pinion bearing started whining, I was s.o.l though I was out of warranty, so I've lost confidence on a product that was highly rated, fortunately I found a 14 bolt out of a nnbs and put that in.........
Fastest D1 Procharged Truck
Charlie Murphy!
Does anyone know if there is a kit I can order that would come with all the shims, ring gear bolts, bearings etc? If so could someone point me in the right direction please?
Thanks!
On this note, I'd like to install mine myself as well. It's been about a decade since I've I setup gears, but I'm confident I can pull it off with the various write ups floating around.
Thanks!
Thanks!
murderedSS
27
10-12-2015 11:13 AM
