Detroit TruTrac vs. Eaton LSD
#25
I've said it before and I'll say it again. The trutrac is nothing more than a torque multiplying rear differential. In a nutshell it can only send power to the left rear when there is traction or resistance on the right rear. For ice, snow, and offroad where your right rear tire could get hung up in the air and be subjected to zero traction conditions, torsen style differentials suck. I know since I've run 2 of them in different trucks. Should have learned my lesson the first time. Now for bare tar or dry pavement, they work just fine but that's it. If you snap or pop the clutch with a manual transmission truck and send that right rear tire into a frazzle, it won't send the power to the other wheel because there's no resistance on the right rear. On a eaton LSD with clutches, both back tires are always moving forward at all times. Under cornering the clutches break free to allow the wheels to spin at different speeds, however when driving straight they're both locked all the time so that if a tire gets in a slick condition or is suspended in the air, it'll still transfer power to the left rear since the axles are held together with clutches, make sense?
#26
Sorry hirdlej, but clutch type diffs can slip too (ask any one with an old worn out factory clutch type posi) when one wheel is fully loaded and the other is not because they are load sensitive too. The only way to have a FULLY lock diff is with a spool, mini spool or a Detroit type ratcheting locker (and even they, in the right circumstances, can not lock), because unlike the friction locker, torsion and clutch type, they are a mechanical lock using interlocking teeth.
