Detroit TruTrac vs. Eaton LSD
#61
11 Second Hall Moniter
Info taken from Eaton's website FAQ. Notable differences between operations of Eaton LSD(Posi) and Truetrac.
Eaton Posi
What kind of oil should I use? Can I use synthetics? Do I need a friction additive/modifier?
Eaton Posi units perform best when using GL4 (or better) mineral/petroleum based gear oil. A four ounce bottle of friction additive/modifier is also necessary for optimum performance.
Is the Eaton Posi Rebuildable?
Yes. There are three main types of service kits available - internal spider and axle gear kits, clutch kits, and preload spring & plate kits.
Can I upgrade my Eaton Posi?
Yes. Both the clutch disks and the preload springs can be upgraded for extreme off road and drag racing applications. Posi units come equipped with 400lb of preload. They can be upgraded to 800lb, or even downgraded to 300 or 200lbs options.
Clutches - There are several types of clutch service kits. They range from the OE, 18 disc (standard), the 24 disc (high performance), and the modern day, high tech 14 disc carbon fiber design.
What is the warranty for the Eaton Posi?
The Eaton Posi is guaranteed for one year against manufacturers defects.
Truetrac
What kind of oil should I use? Can I use synthetic? Do I need friction additive/modifier?
A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required.
Can I use the stock bearings?
In most cases the Truetrac units work with the factory (stock) bearings. The exceptions are: 10 bolt 8.5\8.6 GM axles, the “Performance” Dana 35 & 44 and GM12 bolt with 35 spline axles. No other “special” setup is required.
What kind of break-in is required?
The Truetrac units do not require a break in. The unit’s internals will take a little time (depending on driving conditions) to “seat.” Afterwards there will be a slight improvement in its performance.
When does the Truetrac lock up?
The Truetrac is a helical gear limited slip differential and never “locks up”. The Truetrac operates by transferring power from the spinning wheel to the wheel with the most traction. If one tire breaks traction, the amount of rotation (or spin) is controlled. The torque is then sent to the other tire that still has traction.
I use my car on the street and on the strip, will the Truetrac hold up?
On the street, the operation of the Truetrac will be transparent. You will not know it is there until you need it. In racing situations the unit will apply torque to both tires and launch straight as an arrow, time after time.
How much horsepower and torque will the Truetrac take?
There are many factors to consider when determining if a specific differential will last in your vehicle. Horsepower and torque are important factors. However, the weight of the car, tire height/width, the terrain and suspension are all important things to take into consideration.
For example, a setup that uses street tires will live longer because both tires will break loose and spin before any real strain is put on the unit. But as the tire gets wider, the stress on the unit increases because the traction is greater. When in doubt, the best bet is to call us with your specific application and driving conditions.
Can Truetrac be used in the front axles of full time 4 wheel drive jeeps and trucks?
Yes, it can. You will find will find Truetrac differentials to be very smooth yet effective in either end of your vehicle.
Can I repair the Truetrac if I need to?
The worm gears inside a Trutrac are maintenance free, and do not require regular service. Internal failure usually results in the damage of the worm gear pockets. Therefore, they are not rebuildable.
What is the warranty?
The Truetrac unit is covered for one year from date of purchase against defects in materials and workmanship up to a 38"
Eaton Posi
Truetrac
lycominghunter
26
09-25-2015 07:50 AM
GMCtrk
09-11-2015 09:04 AM
