Did I Lose the Tranny or Converter?
Old 02-01-2014 | 08:23 PM
  #61
GREENSIERRA's Avatar
instead of a deeper pan is it possible to run just a little extra fluid in the stock pan?
once I put my header wrap on my crossover I wont have any room at all
Old 02-02-2014 | 04:02 AM
  #62
03sierraslt's Avatar
I don't remember what converter you have but if it's a good triple disk it should feel like another gear when it locks. If it does not then the lockup settings need adjusted because it's slipping the converter clutch on engagement.
Old 02-02-2014 | 04:50 AM
  #63
GMCtrk's Avatar
Can't see in the pic but my vavle covers are even red.
I love the simplicity of this setup. I'd like to try a blower in the future.
Old 02-02-2014 | 04:52 AM
  #64
GMCtrk's Avatar
It is recommended to run 1/2 to 1 qt over full on the 80e.
Do NOT skimp out when it comes to installing the transmission and converter. Triple check all your clearances. Install the dipstick and pull the transmission pan before filling with fluid. Measure the distance from the bottom of the dispstick to the interface of the pan and case. That is the proper fluid level. The upper end of "full" on my stock dipstick was well under this level.
Old 02-02-2014 | 05:13 AM
  #65
I know with my trans mounted in my truck the fluid level on the dipstick had to be about 1/4" above the full mark to really be full. Checked this by removing pan with dipstick in and marking dipstick based on vavle body to case mating surface. Like GMCtrk mentioned you typically need a extra .5-1qt. When the trans is installed you want the full fluid level to be at the same point as the valve body to case mating surface.
Old 02-02-2014 | 04:42 PM
  #66
good to know.
thanks guys
Oobray
06-13-2022 03:38 AM
blownss27
08-14-2020 08:27 AM
chvy=power
09-08-2015 11:06 AM
Jblake
08-17-2015 12:59 PM
OLD BULL
08-01-2015 05:00 PM
Quick Reply: Did I Lose the Tranny or Converter?
