differential bolt heads stripped
Old 04-02-2009 | 08:06 PM
KeukaZ71's Avatar
Default differential bolt heads stripped
was going to change my diff fluid the other day and the head of the one of the bolts stripped. any suggestions?
Old 04-02-2009 | 08:17 PM
james07shortbed's Avatar
die grind a notch in it so you can get a flat blade screwdriver in it then hit it
with a dead blow hammer and hit and turn tell it bust loose.
Old 04-02-2009 | 08:29 PM
KeukaZ71's Avatar
should i try a vise grip first?
Old 04-02-2009 | 08:32 PM
BlownHD's Avatar
Yes you can do that. If you have a welder, you can also weld a nut to the end of the bolt and then get a wrench on the nut.
Old 04-02-2009 | 08:46 PM
Mangled03gmc's Avatar
Baltimore Whore
Grind the head off the bolt, then use vise grips to get it out...after the cover is off. Or like said weld a nut to it..
Old 04-02-2009 | 09:11 PM
1_fastsilverado's Avatar
If you just want to change the fluid, I'd take out the drain plug under the differential and then refill it through the fill/check plug (obviously haha). I didn't know these had drain plugs on the bottom till tonight when I put my TA girdle on and saw it under there.
Old 04-02-2009 | 09:27 PM
willymac's Avatar
if you are one of the lucky few that have a drain plug on the rearend.
Old 04-02-2009 | 10:50 PM
nonnieselman's Avatar
Id try the notching it and use a flat head screwdriver... if that doesnt work, weld a bolt or nut to it and try that.. if thats not successful then just grind the head off and use visegrips..
Old 04-03-2009 | 12:45 AM
howard quick's Avatar
If you have a welder....save alot of mucking around and just weld a large nut to it.
slowlsx
08-10-2015 06:33 PM
vipergtrdj
08-06-2015 11:19 PM
signguy62
07-27-2015 04:42 PM
fat tony157
07-16-2015 01:35 PM
