Disc to 05 DRUM ???'S
I want to swap over to a 05 drum set up because I want to run 15' Bogart street strip wheels. I can get the whole rear for pretty cheap, but what is involved in the swap? I searched , but ramdom comments where the best I could find. I know you can grind s-10 calipers down a lot and run a 15, but I want a streetable wheel. Any real world ino PLEASE. Thanks.
Your best bet is to get a complete set up and bolt it in for simplicity. But just the brakes can be swaped...
As far as function. They will work but they use different pressures. I have only worked with drum to disc conversion. On a drum to disc swap, if you do a panic stop, it will lock up the disc in the rear... So in theory the drums may not get enough pressure and the front's might be working harder...
lycominghunter
26
09-25-2015 08:50 AM
