disc rearend to drum rearend..straight forward swap?
Old 10-21-2012, 09:52 PM
Onetogofast's Avatar
I remember at one point a while back I put disc on the back of a jeep project and took the regulator plunger out of the end of the distribution block right after the master cylinder and when I was hard on the brakes they locked up. Since you are going the other way you might just swap the block with what you take the axle out of.
Old 10-21-2012, 10:19 PM
Custm2500's Rude Friend
1FastBrick's Avatar
It is controlled in the ABS module on these vehicles. I wouldn't mess with them on these vehicles.
I looked into having the calibration changed but there is so many unknown factors and no one wants to take the liability to flash it. You need the dealer tool's and the dealer calibration files to flash that module.
It would be easier to put a manual proportion control valve in line with the rear brakes. there only like $40.
Old 10-21-2012, 10:59 PM
2doorfury's Avatar
Would that mean running new brake lines? And would effect abs?
Old 10-22-2012, 12:51 AM
1FastBrick's Avatar
No on the first one and I am not 100% on the second. I don't think so. Your only restricting the volume and limiting the max pressure.
Old 10-22-2012, 02:08 AM
2doorfury's Avatar
Gotcha. Well i guess ill go ahead and do the swap and take care of those problems. Doesnt sound like itll give me too much of a headache.
Old 11-03-2012, 05:48 PM
2doorfury's Avatar
So on a drum setup, does the brake lines run from each side of the axle to a brake "T" on top of the middle of the axle?
Old 11-05-2012, 02:54 AM
1FastBrick's Avatar
I am, Not sure I don't have a 10 bolt with drums. I would imagine there fairly close as people claim to have swapped them straight across.
Bluecollar Hotrods
06-11-2024 11:37 PM
chopperloco
07-10-2016 10:45 PM
Deceptarado
07-08-2015 05:24 PM
mrgrim
07-08-2015 08:12 AM
Quick Reply: disc rearend to drum rearend..straight forward swap?
