View Poll Results: gasket or silicone
gasket
11
35.48%
silicone
48.39%
gasket and silicone
16.13%
Voters: 31. You may not vote on this poll
Do you use silicone or a gasket for your rear diff?
Old 10-26-2010, 02:52 PM
pewterliftedz's Avatar
Post Do you use silicone or a gasket for your rear diff?
the rear diff has a slight leak so im going to be redoing it. the last time i did it i used the gasket and siicone. some have said just use silicone.
what do you use?
If you use silicone, how long do u let it sit before adding the lubricant?
Old 10-26-2010, 02:56 PM
11 Second Club
Phantom's Avatar
We just use silicone, never a leak
Old 10-26-2010, 02:59 PM
I have a gauge for that
Atomic's Avatar
black rtv
spread it evenly on the cover and put it on, I usually only give it a few minutes before putting the cover on, never had an issue
Old 10-26-2010, 03:09 PM
Silverado53's Avatar
I prefer to use a factory gasket. Whatever you do never use both. Also make sure there is no fluid leaking onto the sealing surface before you get the cover up.
HIPSI's Avatar
30 mins and I fill.
Mrgoodwrench3's Avatar
GM paper gasket, dry, never had a problem.
Old 10-26-2010, 03:15 PM
sounds good guys... now i know not to use both.
guess i know y it leaking huh haha
Old 10-26-2010, 03:16 PM
hirdlej's Avatar
This ^^^ There's no reason to run sillycone on a gasket EVER if it's properly installed.
Old 10-26-2010, 04:55 PM
Bigredmariner's Avatar
Clean diff, straight clean cover and gasket has always worked for me.
Old 10-26-2010, 05:14 PM
JakeBrakeIH's Avatar
Originally Posted by Atomic
black rtv
Same here...
Quick Reply: Do you use silicone or a gasket for your rear diff?
