Does anyone know how many splines are on...
the tail/main shaft of an automatic trans for a 4x4, 1/2 ton, that fits in the transfer case?
Thanks.
Thanks.
Looks like 27 spline on a 4l60e. 32 spline on a 4l80e.
Here's an excerpt from the t-case section of the service manual:
There are two versions of the NVG 246 EAU, which depend on the transmission applications and vehicle applications. If the vehicle is equipped with a transmission RPO M30, the transmission splines in the input gear will have 27 teeth. With this application the planetary carrier assembly will have 3 pinion gears. If the vehicle is equipped with transmission RPO MT1 or MN8, the transmission splines in the input gear will have 32 teeth. The planetary carrier assembly on this application will have 6 pinion gears.
iregret
09-07-2015 01:20 PM
