drive shaft viberation
formerly 1BADC10 (12/14/2011)
get that puppy checked for balancing. Tube likely to be bent. It won't look bent by eyballing it, but .040" is a lot at 90+mph. I know this first-hand. ![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
On second thought... have you changed the stance on the truck. I just noticed your avatar. Looks like it's lowered. Nice BTW!
Check the pinion angle. May be more than recommended 1 - 3 degrees.
![Thumb](https://www.performancetrucks.net/forums/images/smilies2/thumb.gif)
11 Second Truck Club
It is your driveshaft and it will fly off sooner or later. You need a 2pc from an extended cab, fits like a glove, just need to build a crossmember for it.
So i talked to a guy today at the used parts place, he's got what i need but swears it wont work, (he is a expert you know) ha, anyway has anyone actually done this swap? If so what year did you get your parts from?
My cousin just got it done on his NNBS 07 and no vibrations at all.
