Driveline clunk
Driveline clunk
When going into gear sometimes but always when I leave a light there is a clunk coming from what seems like the differentials. The u joints seem to be fine, I put the truck into neutral, and jerked both drive shafts around and I get the same clunk. The shafts will turn about 1/4 of the way and then will clunk. What would cause this? Transfer case? Both differentials? I don't know if I tested it wrong
what truck do you have?
I have a 08 CCSB and it does the same thing. My fix for it is every time I do an oil change I pull the drive shaft clean all the grease off the splines that slip on the trans and fill the splines back up with some heavy duty grease.
my 04 4wd does this, sometimes ill slow down if a car is turning infront of me go to take off again I hear a clunk or sometimes if I do a complete stop It does it, I replaced the u joints, I think mine is either the diff or transfer case
slonlow2000
04-18-2016 04:08 PM
Shtbox
03-28-2016 04:31 PM
Brettk
03-27-2016 12:32 PM
