Driveshaft #2 popped in half
Old 12-06-2005, 08:36 PM
  #21
La Riddler's Avatar
Originally Posted by Naked AV
Highly doubtful you can see a pinion angle issue. Even experts can't see them, they have to perform a measurement. If you choose to forego this measurement, you could be asking for another broken driveshaft (see above pic for reference).
I had three places measure my angles and they all did it for free. Took all of like five minutes. You need two measurements: (1) Transmission output shaft angle, and (2) Pinion angle. They should match and be opposite.
Before I fixed my issue, the angles were -4/+7 (transmission shaft down/pinion up). When I corrected the issue with longer lower rear control arms, the angles were -4/+3. Perfect for high power launches, because under torque, the pinion moves a degree to +4.
I think I got a brain freeze. I'll have to check with some local shops then.
Thanks for the advice. What are my options if the angle isn't right?
Old 12-06-2005, 08:54 PM
  #22
Mr. Sandog's Avatar
Since you have leaf springs it is easy, all you need are some shims...they are like $2-$3 each, and very easy to install. Me, I had to buy some new lower control arms at $200+.
Old 12-06-2005, 08:56 PM
  #23
La Riddler's Avatar
What do you measure the angle with?
00loudchevy
12-03-2015 05:54 PM
turbo6c3
10-05-2015 06:11 PM
jscherbs
09-30-2015 07:54 AM
97_ek
09-23-2015 09:16 PM
ice17
09-22-2015 05:18 PM
Quick Reply: Driveshaft #2 popped in half
