Driveshaft #2 popped in half
#21
Originally Posted by Naked AV
Highly doubtful you can see a pinion angle issue. Even experts can't see them, they have to perform a measurement. If you choose to forego this measurement, you could be asking for another broken driveshaft (see above pic for reference).
I had three places measure my angles and they all did it for free. Took all of like five minutes. You need two measurements: (1) Transmission output shaft angle, and (2) Pinion angle. They should match and be opposite.
Before I fixed my issue, the angles were -4/+7 (transmission shaft down/pinion up). When I corrected the issue with longer lower rear control arms, the angles were -4/+3. Perfect for high power launches, because under torque, the pinion moves a degree to +4.
I think I got a brain freeze. I'll have to check with some local shops then.
Thanks for the advice. What are my options if the angle isn't right?
#22
jscherbs
09-30-2015 07:54 AM
ice17
09-22-2015 05:18 PM
