Is this Driveshaft guy smoking crack or what?
Well i called up Driveshaft Specialist in San Antonio to see what he recommended for my driveshaft for my truck... This guy said i needed a 5inch Aluminum shaft if i am going to be crossing the traps at 105-110 (mods in sig)... He said a steel shaft would come apart and be no good....
My guy will go out of his way to get you what you need, dont matter the cost. if you want cheap he can do it, if you want top of the line, he will hook you up..
i sent you my number, ill go to lunch with him tom and see what he can do.
Also, need some measurements. what brand Ujoints do you want in it? what about a yoke also?
whats your DS length? those guys are very nice and good to deal with unlike every other driveshaft company i talked to. they do make steel shafts but he prob figured you would be out of critical speed range with the steel. ive had my 5" alum 72" long shaft from them over 6k rpm with not a hint of a problem. top notch in my book
the nascar guys turn 9-10k rpm for hours on end with a 4" steel shaft but they are only 44" long. the shorter, bigger dia, and lighter they are the faster you can spin them hence the reason why the alum one is 5" dia. although i do not think a steel one would come apart at that speed (depends on your rear gear and tire size) the 5" alum would be the safer piece
well I just got a driveshaft from them, and they were SUPER nice to deal with. Told me for my driveshaft lengh, which was 48.5inches (4x4 rcsb), the critical driveshaft speed is 15,000+ rpms, he actually gave me a hard figure but I cant remember it.
Im not sure if you mentioned your driveshaft's lengh because that has ALOT to do with what they would recommend, I asked for the best they could offer which is why I ended up with the 5x .125 aluminum driveshaft. They do make them in 3,4,5 inches im sure if you tell them you just want to be safe up to 110-120mph they could figure something out for you. Plus I dont know why people mention RPM when engine RPM has nothing to do with the driveshaft speed, its driveshaft RPM thats important and you can reverse calculate the speed by using your tire diameter and rear end ratio or using engine rpm, and gear ratio.
