Is this Driveshaft guy smoking crack or what?
Old 02-29-2012, 08:43 PM
  #21
Robert91RS's Avatar
Just as a comparison, Denny's driveshafts only builds the 3.5" "nitrous ready" shafts up 56" center to center so even they don't feel the 3.5" tubing is safe at the lengths most of us need.
Old 02-29-2012, 08:44 PM
  #22
Resident Retard
BlackGMC's Avatar
Ya. After i measured my stocker which is 4.0 aluminum the 5.0 doesnt sound so crazy
Old 02-29-2012, 08:45 PM
  #23
sharpshooter's Avatar
I run a 3.5" steel performer series from driveshaft specialist.They also built my front DS.
Old 02-29-2012, 08:46 PM
  #24
ayousef's Avatar
Originally Posted by schino
the 5" .125 thick will prob be stronger then a 3.5" .065 thick 4130 DS. but given my lenth which i know is over a foot longer then the OP's the steel absolutely will not hold the rpm i turn which is prob why they recommended the alum. Brent the owner of driveshaft specialists prob heard truck and said the aluminum since thats what most of us need.
about the money in their pocket, when i got mine i looked up the part numbers of the components used to build it and purely material alone is over $400 for someone to buy. that 5" tube is over $200 itself for 80" long. they already built mine and sent it and never even had my credit card info.
i always figure by engine rpm because we would be going through traps in 3rd gear 1:1 ratio. any drag car you see even a pro mod doing 240mph doesnt have overdrive so they will only be turning engine rpm through the traps.
agreed, with a 1:1 gear ratio, engine rpm should equal driveshaft rpm
Old 02-29-2012, 08:48 PM
  #25
ayousef's Avatar
any reason you had them build the front driveshaft?
blackgmc, how come your stock driveshaft is aluminum?
Old 02-29-2012, 08:51 PM
  #26
Resident Retard
BlackGMC's Avatar
Well the guy for driveshaft specialist said it was AL. But honestly i did not even motice. It may be steel.
Old 02-29-2012, 08:52 PM
  #27
When you do the 80E swap on a 4wd you need a longer front ds.Most people run the longer front out of a 2500 but I needed it longer than those also.Do to the lift kit.
  #28
Robert91RS's Avatar
Lots of the stockers are. But they are thin and cheap in comparison.
Old 02-29-2012, 09:59 PM
  #29
JFOLM's Avatar
Mine stocker is aluminum and I feel like I could bend it over my knee. I cringe when I go over 100 lol.
Old 02-29-2012, 11:17 PM
  #30
I have a gauge for that
Atomic's Avatar
Ive had a 4" AL, a 5" AL, and a 3.5" steel from them, all quality parts.
Steel has a higher critical speed due to the much higher modulus of elasticity of the material; thats why they can afford to be a smaller diameter for the same application. AL is lighter, so it saves you a few hp, but you need a larger diameter. The weight of the shaft does not matter as far as critical speed is concerned. The only thing that matters for critical speed is modulus of elasticity, diameter (inner and outer), and length.
Quick Reply: Is this Driveshaft guy smoking crack or what?
