driving without VSS connected
Old 12-15-2011 | 06:57 PM
charcoal03silvy's Avatar
Default driving without VSS connected
When i was dropping my trans last i forget to unplug the vss pigtail and broke the wires off really close to the plug.
Can I drive without it plugged in without any issue until i get a new pigtail to splice in? I know i won't have a speedo reading, but will the trans operate normally?
Old 12-15-2011 | 07:30 PM
thunder550's Avatar
High on diesel fumes
IIRC you'll be stuck in gear, trans won't shift because the computer doesn't know how fast you are going.
Old 12-15-2011 | 07:35 PM
would manually shifting 1,2,3 etc work? I need to just fix it but idk if a dealer will have the connector in stock
Old 12-15-2011 | 07:40 PM
brent1976's Avatar
11 Second Club
EFI Connection, LLC - Item Details
If you can't get it quick from the dealer, I got this pretty quick when I did my 80e swap.
Old 12-15-2011 | 07:51 PM
thanks!
Old 12-15-2011 | 08:33 PM
thunder550's Avatar
Not unless you had a full manual valve body in the trans.
wcrum17841
08-24-2015 08:30 AM
05GMC4.8
08-07-2015 09:55 PM
atxlt
07-20-2015 11:06 PM
rojeho
07-12-2015 06:10 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: driving without VSS connected
