Drop gas tank for hotchkis install?
Old 04-20-2005, 09:54 AM
ceomall's Avatar
Default Drop gas tank for hotchkis install?
I have read that you need to drop the gas tank to install the hotchkis rear swaybar. Is this really true? If so, how hard is it to do and how much do you need to drop the tank.
Thanks,
Chris
Old 04-20-2005, 10:01 AM
Dub Silverado's Avatar
Man, i hope thats not truc, cause im doin it this weekend.
Old 04-20-2005, 10:29 AM
ecthelion's Avatar
Location: Formerly Hayden, AL . . . Now Attleboro Falls, MA
On my hotchkis rear bar ('01 RCSB Z71), I was able to get the drivers side bracket into the frame rail through a hole in the side of the frame rail and then get it positioned correctly using a loop of string . . . some other guys have had similar success by using some wire to slide it into position . . . so NO, you don't have to drop the tank.
Old 04-20-2005, 10:51 AM
Kano's Avatar
its not that bad
just loosen it and push it over a little if you have to
another thing on the leafs
dont try to do one side at a time..lol
Old 04-20-2005, 10:57 AM
Guess i better drive around and burn some gas off before I start working on it this weekend
Old 04-20-2005, 02:08 PM
BigKID's Avatar
All I did with mine is loosen it and slide it to the side to get the bolt in/out. So, no, you dont have to drop it completely.
Old 04-20-2005, 05:00 PM
D Man's Avatar
I did mine and didn't have to drop the tank or loosen it. You should be fine
Old 04-20-2005, 05:33 PM
negativeswitches's Avatar
what about the leafs?
Old 04-20-2005, 06:32 PM
Kano's Avatar
those have to be dropped JK
what do you mean?
Old 04-20-2005, 06:41 PM
arou you talking about drop leafs? what does the leafs have to do with the sway bar?
i already 4/6'd the truck and put the front swaybar on still have to do the rear feels useless to me to put it on till i get my 20's and lo pro tires casue the stock 17's just roll over on the sidewall all the time
Quick Reply: Drop gas tank for hotchkis install?
