Drop Shackles
Drop Shackles
Has anyone with 2" drop shackels noticed a horrible squeaking?! I put some Belltechs on mine and can't shake the squeaks. I let all of the weight on the springs before tightening the bolts and the noise seems to be coming from the binders towards the front and back of the springs.
I have the Belltech shackles on my truck and they do not squeak. Did you snug the bolts with the truck's weight on the suspension? Notice I said "snug" and not torqued or tightened. Never snug suspension parts with the vehicle off the ground.
I sure wish mine just squeaked with the 2" shackles. My truck vibrates bad at 15-18mph right after adding them.
Tried a 2* shim both ways, and it didn't help.
Belltech and McGaughy don't know why it would be doing this either.
That's why I wish mine "just" squeaked!
Jim
Jim
I tightened the bolts on the ground. If I put lubrication on the "binders" it stops for a while, then starts again. I bought a grease fiitting with a needle and shot the rubber on all shackel componets full of grease. Just annoying.
Originally Posted by simple02
my truck used to squeak until i loosened then lighty tightened the nuts back...i also found that you should spray lithium grease between the leafs on the spring perch
This actually does help. Mine still squeaks occassionally, but not near as bad before I used the white lithium grease.
