Drop Shackles
Old 11-13-2006, 08:15 PM
11 Second Truck Club
Cuerva's Avatar
I just installed 2" beltech shackles to the 6" flip kit that I have and don't have any squeeking.
Old 11-13-2006, 10:16 PM
jakebdb56's Avatar
the grease will help a lot.
do the shackles allow for one side to be "lower" than the other. jw, cuz I wanna get rid of the chevy lean. driver side sits a little lower cuz fuel tank, and I'm a fatass
Old 11-15-2006, 01:16 AM
jakebdb56's Avatar
anyone know if they allow for one side to be lower than the other?
Old 11-15-2006, 09:52 PM
blue 01's Avatar
My DJM have two sets of holes. About 1 inch apart. To use the lower holes you have to trim out the radius in the leaf spring clearance area on the shackel so it doesn't hit the round end of the leaf spring.
Old 11-15-2006, 10:38 PM
StrokerAce03's Avatar
I have DJM's and they squeaked when I first put them on. I think I loosed the nuts a little and sprayed the bolts down with some CRC silicone. Any time you go from rubber bushings to polyurethane like is on the DJM you are gonna experience a little squeak. Every poly bushing I've ever seen squeaks a little.
Old 11-16-2006, 11:19 AM
white06's Avatar
The squeaking is coming from the binders on the front and back of the springs. I f they're wet, no noise; dry sounds like ****. Is there anyway to get grease in there?
Old 11-19-2006, 05:48 PM
white06's Avatar
Finally had time to fix it! Had to put a pry bar between the springs until the plastic seperator was loose and then greased the living **** out of them.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Chewy07
11-14-2015 09:46 PM
Gadgetized
10-22-2015 09:06 AM
vmaxpro
09-28-2015 11:10 AM
twake_410
09-25-2015 10:09 PM
Quick Reply: Drop Shackles
