Drop Shackles
the grease will help a lot.
do the shackles allow for one side to be "lower" than the other. jw, cuz I wanna get rid of the chevy lean. driver side sits a little lower cuz fuel tank, and I'm a fatass
Originally Posted by jakebdb56
anyone know if they allow for one side to be lower than the other?
I have DJM's and they squeaked when I first put them on. I think I loosed the nuts a little and sprayed the bolts down with some CRC silicone. Any time you go from rubber bushings to polyurethane like is on the DJM you are gonna experience a little squeak. Every poly bushing I've ever seen squeaks a little.
The squeaking is coming from the binders on the front and back of the springs. I f they're wet, no noise; dry sounds like ****. Is there anyway to get grease in there?
Finally had time to fix it! Had to put a pry bar between the springs until the plastic seperator was loose and then greased the living **** out of them.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
