Dropped My Truck
Give it some time to get use to it. I have a 2/4 and still find my self slamming it and scrapin it. Just learn to cruise and unless your familiar with the road try not to haul *** on it , you will find huge ditch size pot holes. The best part is when your hauling *** and see the pot hole and cant do anything about it.By the way your truck will ride stiffer if you plan on changing your stock meaty sidewall tires to bigger rims and lower profile. Also depending on the wheel and tire combo your truck may even end up lower with a tire not as tall.
Belltech has an alignment kit that will give you almost 2* of adjustment. I think its part number 4910, but I'd give them a call to be sure. I also have the DJM 4" lower arms, and I did it to my truck after fixing the chevy lean, cut the pass. coil. I'd use this kit before ordering the upper arms, (they are not cheap). You'll have to pull the upper arm and remove the alignment cams, then elongate the slots. Then you re install the new cams, and install the upper arms. I'll call tomorrow for the part number.
A lot of people run Doetsch Tech shocks. Personally I am running some qa1 12 way adjustables, but they are not cheap by any means. As for the scrapping and bottoming out, you have to realize you are driving a lowered truck and to take it easy. I rarely scrap or bottom out, and I sit a little lower cause I am running a 27.7" tire compared to your 30" tire. Steep driveways will have to be taken at an angle to avoid scrapping. Like said, just give it some time to adjust and watch your surroundings so you are aware of anything before its too late.
btw, truck looks good
yeah when your that low, you have to remember ways of getting around, i plan how i get into shopping malls and places like that to avoid speedbumps and harsh dips. im riding on air and i could pop it up, but i like riding low. seems like the lower i am, the more fun it is to drive. im running monroes, but they are not in the stock location.
im fully aware that drving habbits have to change how ever my problem is im hitting things even when im being cautious ex. the other day i come to a complete stop and see a little bump in the road ahead about middle of intersection, i go over almost at an idle and front end just kissed the pavement with a nice thump and scrape.. my shocks are just WAY to soft. what shocks should i go with that will be able to handdle a 4/6 and never let me hit ground?
