Dropping 07 OBS short crew 4X
I recently picked up an o7 old body style short crew. I pulled the rear blocks out of the back to drop the rear and it helped a bunch. I'm wanting to drop it a bit more Is it just a matter of spindles up front and drop hangers for the rear. After looking at it with just the blocks removed the rear bumpstops are super close. Do I need to get a set for a 2wd or just wack the plate off of the frame and forget about it. My other question revolves around pinion angle will I need to get a set of degree shims for the rear to avoid problems. Or is there a complete turnkey package I can get that does it all. Thanks.
PT's Slowest Truck
My setup consists of Belltech lowering keys, lift blocks removed, 2" shackles, and spring clamps...the poor man's drop. If I had the cash and didn't put 16" wheels on in the winter, I probably would have done spindles up front. Maybe some day I'll add spindles and hangers and go even lower
