Dropping tranny pan, how much fluid needed?
Old 01-11-2007 | 07:41 PM
2002C5COUPE's Avatar
Originally Posted by BlackGMC
I am about to drop my tranny pan and install a drain. How much fluid do I need to fill it back up?
Thanks
You're going to install a drain plug? Mine already had one from the factory.
Old 01-11-2007 | 08:43 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Yeah, but can ya get it open? Tried that on my Yukon & Silvy, and the plug laughed at me. Then most of the folks I know say that you won't be able to remove it.
Old 01-12-2007 | 11:34 AM
budhayes3's Avatar
PT's Slowest Truck
Mine came with a plug from the factory that is a torx fastener...that POS stripped in seconds. I even put a floor jack and block of wood under the rachet head to hold the socket in there deep and tight (as soon as I saw the Torx, I knew I was in trouble ) I unbolted the pan and drained it the old school way. I believe they changed it to a regular 6 point fastener in 00 or 01, but from what I've read, they too are way over-torqued from the factory. You may be able to remove the factory plug once the pan is off and you have it on a bench, in a vise, then just install a new factory drain plug and gasket...probably have to hammer the poop out of the plug with a chizel or something and risk damaging the pan though
Old 01-12-2007 | 02:56 PM
yeah i got it open, but it was REALLY tight. it started to strip. next time i do a service im replacing it with a new plug
Old 01-12-2007 | 03:02 PM
BlackGMC's Avatar
Resident Retard
Mine did not come with one so I had to add one. Only like $5 at the autoparts store.
ZONES89RS
21
09-24-2015 06:58 PM
Bluecollar Hotrods
07-16-2015 09:52 PM
Aboss
07-09-2015 11:28 AM
Sbrown06
07-09-2015 10:21 AM
Quick Reply: Dropping tranny pan, how much fluid needed?
